Portal for ArcGIS Print Error
272
10-31-2019 09:08 AM
James_Armstrong
I have Portal for ArcGIS working  well at two locations.  The biggest issue is that users get a print error when accessing an image service from an outside agency.  I have attached a image of the error message.
If the  background image is changes, printing seems to work fine.  Both instances of Portal experience the same thing.
I have communicate with the agency, but have not found a solution - other than use a different service, which I would rather not do.
thanks
James Armstrong
Reply
JonathanQuinn
Esri Frequent Contributor
When printing, the machine hosting the printing tools used in the web application is making an outbound request to all URLs in your web application/webmap. It sounds like your ArcGIS Server machine doesn't have access to the URLs that are being printed, likely due to a firewall. On the Server machine, see if you can reach the REST endpoint in a browser:
Imagery/Orthoimagery_Latest (ImageServer)
If not, printing that service won't work.
Reply
