Portal for arcgis: change map viewer logo?
2128
02-15-2016 05:45 AM
Arpa_PiemonteGeoportal_Team
Occasional Contributor II
Is it possible to change the logo in the Map Viewer's  low-right corner?
In the Portal (10.3) customization setting seem to be only possible change the general page graphic elements.
Thank you
Enrico
Tags (1)
DerekLaw
Esri Esteemed Contributor
Hi Arpa,
Q) Is it possible to change the logo in the Map Viewer's  low-right corner?
No, this is not an option. The 'esri' logo is present to credit the Esri powered basemaps in the map viewer.
Hope this helps,
Hi Derek,
Thank you for the answer.
We actually don't use esri basemap but our local detailed  basesmaps
I see also that basemap credits are maneged by the informatin specified in the credit field in the webmap setting (i.e Openstreetmap basemap) that appear like on-screen text in the mapviewer bottom.
I think that the logo on  map viewer shoud be a inportant customization options,  to brand correctly the Portal application. The same thing is possible in any web application customization option.
Enrico
DerekLaw
Hi Arpa,
Please submit your enhancement request on the ArcGIS Ideas site,
Esri Arcgis Ideas | Ideas Submission Portal
Derek
