Point Symbol ArcBug
1616
09-26-2013 06:56 AM
johnevaskovich
Points symbolized with multiple fields and with halos.
Turn Use Symbol Levels on and the halos disappear.
Experienced with shape files and feature classes, 9.3, 10.1 and 10.2.
See attached screen shots for clarification.
An ArcBug or some sort of ArcFeature?
NidhinKarthikeyan
I observed the same behavior which you had mentioned. I'm not sure whether this is a bug. Sometimes this behavior might be as designed. It would be a good idea to contact ESRI Technical Support.
MatthewPayne
Nidhin,
To update you, John did submit a support ticket with us and we have logged a Bug Request for this (NIM095387).
Matt
johnevaskovich
Logged as bug #NIM095387.
Been around since at least 9.3.
NidhinKarthikeyan
John,
Thanks for contacting them and hopefully they will fix it in the next release of DT.
Matt,
Thanks for the info.
