Please help in Unit conversion
1552
06-27-2013 05:30 PM
RuelMacayan1
I get this error when I tried to Import S-57 to Geodatabse. What should I do!
Thanks!!!
[ATTACH=CONFIG]25570[/ATTACH]
MelitaKennedy
Esri Notable Contributor
I haven't used these extensions.
Are you using PLTS or ArcGIS for Maritime: Charting? If the latter, check out this help topic: Applying unit conversion and rounding rules (Maritime Charting)
There's a note on the page that these need to be set up before importing S-57 data.
I found something similar for PLTS when I did a web search.
Melita
