OAuth2 PKCE Flow, will Portal for ArcGIS support this authentication flow?
1509
02-12-2020 01:22 AM
MarkoReiprecht1
Currently Portal for ArcGIS and ArcGIS Online support the "implicite flow" for browser based logins:
Browser-based Named User Login | ArcGIS for Developers
The implicit flow is some kind of "deprecated" and I found following recommandation:
"Public clients such as native apps and JavaScript apps should now use the authorization code flow with the PKCE extension instead."
See https://oauth.net/2/grant-types/implicit/ .
Can I expect that this more secure flow will be supported by ArcGIS Online and Portal for ArcGIS?
Raul_Jimenez
Reading the doc for the authorize endpoint I see this:
Support for PKCE was introduced in 2020 for ArcGIS Online and at version 10.8.1 for ArcGIS Enterprise.
Right know I'm working in this Postman collection to emulate the different flows (using ArcGIS Online / ArcGIS Platform products), but Enterprise should be pretty similar in terms of PKCE.
Hope this helps!
pheede-esri
Hi Marko,
ArcGIS Online added support for the Authorization Code flow with PKCE in the March 2020 update. ArcGIS Enterprise 10.8.1 will have the same support when released later this year.
Sincerely,
Philip
Drugis
Hi Philip
I failed to find PKCE documentation for the latest version of ArcGIS Enterprise.
Has this functionality been released?
Kind regards,
Sigurd
Raul_Jimenez
Hope this helps!
