Network file access via UNC in PopUp Window
3224
08-28-2015 02:36 PM
Douglas_Sauer
Looking to include network based images into Portal app pop-up window (thumbnail and redirect via UNC).
Using UNC path to file but no love in Portal (image does not load/redirect does not work).
Any thoughts? Am I missing something? Can pop-up content include internal network files?
Data sourced from drag 'n drop .csv file.
Douglas_Sauer
Hello Douglas,
It looks like using UNC path for configure popups is not supported at this time:
This document is for ArcGIS Online but Portal should be the same.   There are a couple of workarounds provided in the document as well.
http://support.esri.com/en/knowledgebase/techarticles/detail/43302
Please let me know if this helps.
Kind Regards,
Marko
Esri Canada
Douglas_Sauer
Hello Douglas,
Kind Regards,
Marko
Esri Canada
