Network file access via UNC in PopUp Window
2738
08-28-2015 02:36 PM
DouglasSauer1
New Contributor III
Looking to include network based images into Portal app pop-up window (thumbnail and redirect via UNC).
Using UNC path to file but no love in Portal (image does not load/redirect does not work).
Any thoughts? Am I missing something? Can pop-up content include internal network files?
Data sourced from drag 'n drop .csv file.
DouglasSauer1
New Contributor III
Hello Douglas,
It looks like using UNC path for configure popups is not supported at this time:
This document is for ArcGIS Online but Portal should be the same.   There are a couple of workarounds provided in the document as well.
http://support.esri.com/en/knowledgebase/techarticles/detail/43302
Please let me know if this helps.
Kind Regards,
Marko
Esri Canada
DouglasSauer1
New Contributor III
Hello Douglas,
Kind Regards,
Marko
Esri Canada
