my river (polygon) colour change when it's been imported into image files
1507
03-11-2014 08:45 PM
pramuditamahyastuti
Is there anybody had the same problem and solution?
I have a polygon, it is a river derived from ASTER GDEM.
From 1 scene ASTER, I got rivers, but 1 of them seems to be different.
When I do the layout of a river at big scale, I have a normal layout view.. the river color is blue and the data frame color is none.
But when I exported into an image (jpeg, pdf, tif, etc) it becomes different.
The river color is none BUT the data frame background is blue (as I set the blue color for the river in map view).
Why is that happen only in one of the river??
Please help...
JimCousins
MVP Regular Contributor
It is possible that there is a problem with the geometry of the polygon layer. Run Data Management Tools >> Features >> Repair Geometry, and see if that eliminates this issue.
Best Regards,
Jim
pramuditamahyastuti
Waw..as simple as that..hehe it works successfully!
Thank you, Jim
Best Regards,
Mahyas
