My Portal for ArcGIS 10.3 does not have "Story Map Series" configurable web application template. Aren't Portal for ArcGIS 10.3 and 10.4 supposed to have this particular configurable web application template?
2364
06-29-2016 12:31 PM
SarojThapa1
Occasional Contributor III
I am trying to create a web app that supports like 10 tabs. I am thinking about modifying this template and add the functionalities in the web app.
Thanks
MichaelRobb
In 10.3, I had to download the Story Map series and dump in the portal working directory on the server..
SarojThapa1
Thanks Michael.
SarojThapa1
Hey Michael,
    How do I dump the "Story Map Series" in the portal working directory on the server? Thanks
MichaelRobb
You would take the MapSeries  Folder and dump to c:\Program Files\ArcGIS\Portal\Apps   if installed to default.  There may be one existing already, rename the existing to _OLD and add the new.
Next time in portal, Map Series will be available under Create >> APP >> Using a Template >> Story Map Series
In that MapSeries folder should be an app folder, resources folder an index.html  and license and readme.txt.
SarojThapa1
Thank you so much @Michael Robb.
