Map Projection of Iraq
4116
11-17-2010 11:07 PM
SimonKettle
Occasional Contributor III
I have recently been compiling maps of Iraq on a UTM grid scale, so have been using the UTM grid projection system. However, what projection system and datum should one use when creating maps for the entire country?
MelitaKennedy
Esri Notable Contributor
EPSG (http://www.epsg-registry.org) lists an ED 1950-based Iraq National Grid. We added it at version 10. It uses transverse Mercator. There's a newer IGRS geographic coordinate system, and 3 UTM zones based upon it, but no national grid. IGRS is close to WGS84, according to EPSG.
Melita
SimonKettle
Thank you very much. That is a very useful hyperlink as well.
Best regards,
