How to convert map notes to feature in Portal for ArcGIS
2963
12-15-2014 05:34 PM
khairulamri
Hi
Is there a way or method to convert map notes layer in Portal for ArcGIS to feature layer. FYI, I used Portal for ArcGIS 10.2.1.
I have compared with ArcGIS online, there have an option to save map notes as layer then we can publish that layer as hosted service. however I didn't find that option in Portal for ArcGIS. is it possible to do in Portal for ArcGIS? any advice would helpful.
Many Thanks,
Amri
khairulamri
Finally I found the workaround for this case. I used ago-assistant (https://github.com/esri/ago-assistant) to get feature set notes layer data as json format then convert the data to feature.
khairulamri
