Hi Gerard,
Is your Portal's hosting server configured with a tile cache ArcGIS Data Store? This is a requirement to publish hosted scene layers to your Portal organization.
https://enterprise.arcgis.com/en/portal/latest/use/publish-scenes.htm
-Calvin
Hi Gerard,
-Calvin
I shall do so, thank you very much @Anonymous User !
You might try exporting lidar out at a 3D Scene Object .slpk file then uploading it straight into portal from your contents page. If the option to publish the slpk doesn't appear then it would be an issue with your data store as Calvin mentions.
Thank you @JasonJordan00!
I have created point cloud scene layer package (.slpk file) from LAS and works fine in ArcGIS Pro. But, it is not possible to import this file from ArcGIS Enterprise. Although the import option is activated, doesn't make anything ...
I will check datastore configuration in AE. Thanks again !
