How does collaboration actually communicate from Portal to AGOL?
207
05-06-2021 06:31 PM
GWaltersOZ
New Contributor II
we have set up Portal to ArcGIS Online collaboration so we understand that it communicates between the two however, we do not understand how it does it.
Our internal server is behind a firewall. The services themselves cannot be reached publicly, so could someone describe the ports etc. that are actually used to send the sync packets please?
This is vital for us to present to our security team. Otherwise it is being viewed as some dark magic and can't be trusted.
Gareth
JayantaPoddar
MVP Esteemed Contributor
Please check if  Architecting the ArcGIS System: Best Practices and How distributed collaboration works  provides some relevant information.
Frequently asked questions about distributed collaboration may answer some of your questions like
When collaborating between ArcGIS Enterprise and ArcGIS Online, what changes are required to my network's firewall?
In this configuration, all communication is initiated by the ArcGIS Enterprise portal. As such, network firewall rules must support outbound communication over port 443.
GWaltersOZ
New Contributor II
Thanks @JayantaPoddar  for the note.  I am trying to get something more than the port 443 comment if there is any.
For example, what does it actually send across? Is it just blocks of JSON in each message? Is the data encrypted in the send?
We understand how our applications use API's to send data but this syncing process is not something I seen much about. It is important for our security teams to understand so they know we are sending data securely between the two systems.
JayantaPoddar
Please get in touch with the Esri Technical Support. They should be able to guide you through the process.
