error to access datastore after update/patch
943
07-03-2020 09:31 AM
GeoMapps
hello
i have a server 10.7.1 with portal and the datastore in the same server
windows 2019 on AWS
all was fine but after the apply some updates using the update tool all my hosted service cant be accessed i check and found  and error to acces to datastore , when run
describedatastore
Error encountered: The data store machine may not have been initialized.
when i check the windows service the datastore is running
when i run the datastore configurator i got the image error
regards
mdonnelly
These kind of errors can be tricky. I recommend that you raise a support call with Esri.
Regards,
Mark
TerryLulf
I've encountered a similar error during an upgrade from 18.0 to 19.0. I've opened a ticket with Esri.
Did you have any success with this issue after posting your problem?
