Error 500 at portal for ArcGIS certificate install.
1653
10-22-2019 04:53 AM
MelanieFournier1
New Contributor III
Hi all,
I am trying  to add my  domain certificate to my  Portal but I get  tris error code 500, unable to import certificate.
Have sou Everton Gottéron thaïs issue? Thé certificate is a domain certificate for thé server, I got no errors while installing portal and webadaptor.
thanks for your help.
mélanie
JonasLeksell2
New Contributor III
Hi Melanie,
Have you figured this out or got some help from ESRI support service?
I have seen the same error on my end, after some investigation, I found that the patch "Portal for ArcGIS 10.7.1 Enterprise Sites 2 Patch" was the cause for the error. Is it/was it the same for you?
Regards,
Jonas
MelanieFournier1
New Contributor III
Hi Jonas,
It was not related to the patch. We ask the IT department to re-issue a new certificate for us and it worked. I guess the format was not correct in the first place.
Best,
Mélanie
