DATAFRAME CLIP IN LAYOUT VIEW
1133
13
08-01-2012 10:51 AM
nimitz
Hey all,
I often have to place ZOOMED in areas of maps. The problem that I have is that the new data frame clips don't make a TRANSPARENT BACKGROUND. So, when you clip - the areas of the dataframe are white. I have played around with BACKGROUND and tried NONE but it ALWAYS makes the background white. Is there a way around this?
LucasDanzinger
Esri Frequent Contributor
Hmm, I tried on 10.1 and 10.0 and cannot repro what you are seeing- if I set it to None or Hollow, they both look good and there is no background color. If you call in and create a support ticket, we can do a screenshare and try to figure out what is going on. But, None or Hollow should do what you are asking for.
-Luke
nimitz
I'm enclosing the PDF of what I produced.
[PDF removed on request from poster.]
LucasDanzinger
What are you using to clip the data frame shape? Is it a feature class, specified extents, or something else? I used another feature class to clip and it does not have the background.
nimitz
I created a shapefile to see if that might work, but it doesnt'. The data frame has been rounded 100% - to create a circular call out (this is the issue - when you round the data frame the back stays white.)
Remember, when I export to pdf OR if I print the .mxd, the white still comes in. Pretty frustrating.
LucasDanzinger
Weird, I believe I am doing the same thing but it looks to be working for me. I'm at 10.1...
nimitz
What's weirder is that when I'm in ARCVIEW, the transparency will stay consistent. It's when I print or export to pdf is when the transparency goes out the window. killin' me.
LucasDanzinger
What version including service packs are you at?
DonovanCameron
Occasional Contributor II
Does one of the layers in the data-frame have a transparency or a graphic inserted?
Any layers that have a transparency enabled will cause that "white" background effect and also, exporting to a vector based format will cause the white background to show up.
See: http://forums.arcgis.com/threads/21701-inserting-a-png-or-image
T
he workaround was to export the map to a raster like a jpeg, png, tiff...
I also found recently that if I used ArcMap's export to PDF (from File pulldown) it would show the white background.
I had to "print" the map using a PDF printer driver like "Adobe PDF" which would print the layout to a pdf file and that did not show the white background.
nimitz
I'm on 10.0 with SP4, running on Windows 7 - "Microsoft for life!! j/k:D
Thanks for all the help and suggestions.
