Convert coordinates of a shape file
1226
01-10-2012 07:29 PM
JessicaMeade
I have a shapefile (map) in South_Pole_Lambert_Azimuthal_Equal_Area coordinates.
Is it possible for me to change it so it is projected in UTM WGS 1984 coordinates?
It all looks fine in the arcmap screen, but I want to export it and measure the distance between
the coastline and some tracks using the geospatial modelling environment, so I need the coordinates of the two to match.\
(the tracks are in UTM WGS 1984 zone 21s coordinates).
Thanks very much for any help in advance,
bw
JoeBorgione
Unless I'm missing something, the project function is what you need
