Can Level 1 Name User Download Hosted Feature Layer?
690
06-14-2019 11:51 AM
Pei-SanTsai
New Contributor III
I'm using ArcGIS Enterprise 10.6.1 with federated server.
Is the download feature only available to Level 2 Name User only?
We have an Enterprise Site with Categories for exploring the data. As a Level 2 name user, I’m able to Download data in all different format (shapefile, spreadsheet, KML, Excel, FGDB, GeoJSON & Feature Collection) without any problem, but when a Level 1 name user tried to download the data, it’s show “Status: An error occurred. Downloaded failed.”   How can a Level 1 Name User be able to download a hosted feature layer on internal Portal for ArcGIS?
Portal for ArcGIS documentation under Use --> For Consumer --> Download Data ( https://enterprise.arcgis.com/en/portal/10.6/use/access-data.htm), this seems like everyone should have the ability to download the data?  Is there a special setting that I'll have to enable on my Portal in order to make this available to my organization?
Download Feature
JakeSkinner
Esri Esteemed Contributor
Hi Pei-San,
I haven't tested this, but try executing the Feature Class to Feature Class tool in ArcGIS Pro, or you can try the following tool:
https://community.esri.com/docs/DOC-6496-download-arcgis-online-feature-service-or-arcgis-server-fea...
Pei-SanTsai
New Contributor III
Thank you Jake, but I'm trying to have Level 1 name user be able to download the data via Portal site as some staff might not have ArcGIS Pro installed.  They are using AutoCAD and/or other application.
JakeSkinner
Pei-San Tsai‌ level 1 users have very limited functionality and can only view data.  They will not be able to download datasets.
