We're trying to script publishing feature services that reference our sde data to a server federated to Portal.
I've had success using getWebLayerSharingDraft to publish a MapImage service to the federated server which seems to reference our sde data, and I've had success publishing a Feature Service but it only seems to publish to the HOSTING_SERVER which makes me think it is being stored in the Data Store associated with the Federated Server and thus is only a copy of our sde data.
If you look at the guts of _mp.py for getWebLayerSharingDraft you'll see that FEDERATED_SERVER is only compatible with MAP_IMAGE and that FEATURE is only compatible with MY_HOSTED_SERVICES or HOSTING_SERVER.
I've tried to go the route of using CreateSharingDraft but that only seems to be able to access a standalone_server and not a federated server.
Has anyone had any luck?
I am having the same problem. Have you found a solution yet?
Unfortunately, I have not.
I seem to be having the same problem. Are you getting and error?
Here is what I see..
File "C:/batch/Publish_Service.py", line 359, in <module>
sharing_draft.exportToSDDraft(sddraft_output_filename)
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\sharing.py", line 66, in exportToSDDraft
return _convertArcObjectToPythonObject(self._arc_object.exportToSDDraft(out_sddraft,self))
ValueError: Unable to create the manifest (sddraft file). An unspecified error occurred.
