are service credits present in Portal ?
2107
10
10-23-2017 08:28 AM
SaraEL_MALKI
Occasional Contributor II
Hi guys,
due to this article:
ArcGIS Online | Service Credits
I have known that for an  operation its equal to a credit,
Is it the same thing for Portal for ArcGIS or just for ArcGIS online ?
thanks for your help in advance
rscheitlin
RobertScheitlin__GISP
Sara,
   When using Portal (on premise) You are not connecting with AGOL or consuming credits.
https://community.esri.com/thread/89972#comment-370750
Sara,
SaraEL_MALKI
that means using ArcGIS server with Data Store and Portal, what's the case if I use Federated server ?
That is more of a question for others with federated server experience. dlaw-esristaff
SaraEL_MALKI
Thanks for your help and time Mr. Robert
DerekLaw
Esri Esteemed Contributor
Hi Sara,
Other have already replied to your original question. But for this one: when a Server site is federated with Portal - it just means that you've configured the Server site to use the security model that has been configured for Portal. A federated Server site does not directly affect/consume credits. Only a hosting server with Portal will use credits - as others have explained.
Hope this helps,
SaraEL_MALKI
Hi Derek,
thanks for your response,
a hosting server with Portal means using Portal on premise,isn't it ? which means (as M. Robert said) it does NOT consume credits at all, but you've said the opposite ?
am I getting it wrong ?
Thanks in advance for your clarification
DerekLaw
Hi Sara,
Correct.
Not quite, it depends on how you configure Portal. It is possible for Portal to use credits.
To clarify my reply, I meant to say that if you've configured a hosting server with Portal, AND if you've enabled a proxy user (as others have mentioned in their posts) in Portal, then it may consume credits.
For example, Configure Living Atlas content—Portal for ArcGIS (10.5.x) | ArcGIS Enterprise
Hope this helps,
SaraEL_MALKI
Hi Derek,
is that means that if I configure Portal to use the utility services it starts consuming Credits ?
DerekLaw
Hi Sara,
If you configure utility services with the Esri services from ArcGIS Online, then yes - Portal would consume credits.
Hope this helps,
