Good morning,
I've installed and activated using my "Developer Subscription Premium" the ArcGIS Enterprise Portal Standard version. I see that I've only two users available, a single "creator" user (mine) and a single viewer (unused right now).
I'm just wondering how to add more users, if possible: can someone point me to a documentation page where this is explained?
Thanks.
Hi Diego, to enable the addition of more users, you will need to generate a new Portal license file (.json). This is done through My Esri: https://my.esri.com/. Now, it may be different with a developer account, but with an enterprise account, you select "My Organizations" and then "Licensing".
Look for "License Esri Products" with a big blue Start button.
From there:
Once you click Next, you'll go to a form that allows you to select the number of users of each type to provision, up to the number available to you. After entering those fields, click Next again, and fill out all the info required. I recommend adding some info to the notes field to remind you later of where this license file is used.
Once you've generated the license file, sign into Portal as the admin and go to Organization->Licenses and click the Import Licenses button.
Hope this helps!
From there:
Hope this helps!
Thanks for the detailed explaination, it's something I totally forgot when generating the license file for the first time. Now I checked again and I saw that developer license "premium" provides a total of 2 editors and 3 viewers.
