ArcGIS Enterprise 10.7 / AWS / Load Balancer / Webadaptor
1440
6
05-28-2019 12:43 PM
AdolfoArguello
Hi there!
I have instaled ArcGIS Enterprise using AWS Ubuntu AIM, after install I just upgrade to 10.7 and register the server, datastore and portal.
For now I have two questions.
1. How I have to configure webadaptor in a Ubuntu configuration? This is the folder webadaptor content after the instalation.
I have tryed the configurewebadaptor.sh in tools folder, but I am reall confuse about how to configure the webadaptor.
2. I can access using RDP to connect to my ubuntu server the portal site but only with this url
https://127.0.0.1:7443/arcgis/home
But the portal looks like incomplete.
Also, I have configured a load balancer and add my ArcGis server with 6443 and 7443 ports to my Target group.
When I access to my load balancer dns using 6443 port works like a charm, however to port 7443, always redirect to 127.0.0.1, so it does not keep my dns, I asume this is because my webadaptor is not configured.
If any of you have suggestios, please let me know.
Thanks
JonathanQuinn
Esri Notable Contributor
If you run configurewebadaptor.sh, it'll give you the command line arguments required to register it:
Once you register the web adaptor, if you have an ELB in front of the portal, set the Web Context URL.
AdolfoArguello
Hi Jonathan
I just try, but I receive this error
I have to tell you, this is my first experience installing this software. So, I do not know if I am using the corrects parameters.
Beside, how do you configure your Load Balancer in AWS? especially the ports
Thanks
JonathanQuinn
The web adaptor URL should the local IP address or hostname. In AWS, it'll be the local IP as those machines don't have hostnames:
https://10.0.0.1/arcgis/webadaptor
I'd suggest you look into the CloudFormation templates so you don't have to configure the environments yourself:
https://enterprise.arcgis.com/en/server/latest/cloud/amazon/arcgis-server-architectures-on-aws.htm
DanielUrbach
Occasional Contributor II
Adolfo,
Your ArcGIS Server URL in the screenshot has port 7443, which is the incorrect port.  ArcGIS Server uses port 6443.
-Danny
AdolfoArguello
Hi there.
I just ask for Esri support team to help us to set this configuration.
I'll let you know how this ends
Thanks
AyyazMahmood-Paracha
New Contributor III
Hello,
With the help of Support, you guys have been able to solve this issue?
Thanks
