When attempting to create a Relational data store I receive the following error: java.lang.NullPointerException
I am unsure how to proceed.
Hi Kelly, have you resolved this? Otherwise, the install may not like the GIS Server naming convention?
this error happened to me once. i click back button and tried another time and worked.
I got the same error. It went away when I upgraded the .netframework to the latest version on my server machine.
Thank you, I will attempt that later this afternoon.
Has anyone solved this issue?
I have not yet solved this issue. We currently are just running non-editable (SDE) data on our Portal
I have this question! I installed through of ArcGIS Enterprise Builder in a local machine the Enterprise 10.6 products, but when try configure data store relational, appear this error:
Thank you in advance!!!
Try using the command line tool
http://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm
and in particular
configuredatastore
