ArcGIS Data Store Error
3469
10
01-05-2018 11:25 AM
KellyPilarski
When attempting to create a Relational data store I receive the following error:                                  java.lang.NullPointerException
I am unsure how to proceed.
DavidColey
Hi Kelly, have you resolved this?  Otherwise, the install may not like the GIS Server naming convention?
Alexwang
Occasional Contributor II
this error happened to me once. i click back button and tried another time and worked.
MichaelTorbett
I got the same error. It went away when I upgraded the .netframework  to the latest version on my server machine.
KellyPilarski
Thank you, I will attempt that later this afternoon.
SDGHaiti
Has anyone solved this issue?
KellyPilarski
I have not yet solved this issue. We currently are just running non-editable (SDE) data on our Portal
BraulioGalvez1
I have this question! I installed through of ArcGIS Enterprise Builder in a local machine the Enterprise 10.6 products, but when try configure data store relational, appear this error:
Thank you in advance!!!
SzymonPiskula1
Try using the command line tool
http://enterprise.arcgis.com/en/data-store/latest/install/windows/data-store-utility-reference.htm
and in particular
configuredatastore
BraulioGalvez1
Hi Szymon Piskula‌. Thank you, but appear the same error:
Thank you very much!
Braulio
