Adding a printing service to a Portal Map?
3195
07-21-2014 05:55 AM
ThomasColson
MVP Frequent Contributor
Either I'm missing the obvious place where this is documented how-to, or its not possible? I currently  have a GP service on my ArcGIS Server, works great when tied to a Flex Map in a browser. Users can "print" to several formats, either 11 by 17 or 8.5 by 11, using our organizations REQUIRED map template for publishing printed maps.
I'm migrating my content to Portal, and would like the same functionality.....users can open a map....and there is a "Print" feature....that enables the user to print to PDF, JPG, etc...using the Map Template I've previously set up. The default "Print" button and its output in Portal is horrible.
Is this even possible?
JacobBoyle
Occasional Contributor III
Yeah...
I had to work with Technical Support on this one, long story short, Portal does not support custom templates from a GP Service.  I have yet to figure out a work around.
DerekLaw
Esri Esteemed Contributor
FYI: just to close the loop on this thread,
Portal for ArcGIS 10.4 will support custom print templates (from a GP service) in the Portal map viewer.
Hope this helps,
