Add data widget
1348
03-24-2021 09:27 AM
chris_bayleycd
New Contributor II
Apologies if this is in the wrong place. I've been runinng a webapp through 10.6.1 portal for a couple of year now. The customer has asked for the add data widget to be added to their webapp which I've done straight out of the box. When I try to import a csv file it fails with the following error:
There was an issue.
Generate Features error: Server tool execution failed : ERROR 999999: Something unexpected caused the tool to fail. Please refer to the error help for potential solutions, or contact Esri Technical Support http://esriurl.com/support. ERROR: unable to connect to the server's managed enterprise database. Failed to execute (Generate Features for Portal). Failed. Failed to execute (Generate Features for Portal). Failed.
A support call has been placed but thought I'd try here too.
ShelleySchott
@chris_bayleycd , there is a prerequisite of a hosting server to be configured for the Add Data Widget to work.
https://enterprise.arcgis.com/en/portal/latest/administer/windows/configure-hosting-server-for-porta...
Has this been configured?
Shelley Schott
Senior Consultant, Esri Australia
ShelleySchott
Shelley Schott
chris_bayleycd
New Contributor II
Unlikely. Can you point me to any setup steps as I've not seen anything about this?
Thanks
chris_bayleycd
New Contributor II
Thanks I can now upload a .csv however i get a white screen rather than data layering on top of my map. Any ideas?
