10.5 User Levels
1100
11-08-2016 03:37 PM
PaulDavidson1
Given the new user levels in Portal 10.5:
http://server.arcgis.com/en/portal/10.5/administer/windows/roles.htm
Two questions:
Is it correct that a viewer, level 1, still requires a named user account?
Are the licensing costs going to change based on the number of named users at each Level?
dlaw-esristaff‌ ?
DerekLaw
Esri Esteemed Contributor
Hi Paul,
Q1) Is it correct that a viewer, level 1, still requires a named user account?
A1) Yes, level 1 is still a named user account.
Q2) Are the licensing costs going to change based on the number of named users at each Level?
A2) I can't comment on this as ArcGIS 10.5 is not final. I suggest you reach out to your local Esri account manager/Distributor to get more details.
Hope this helps,
DerekLaw
Hi Paul,
Hope this helps,
