Your license file must contain at least one user type license that is compatible with the administrator role.
202
05-07-2021 02:09 PM
cloneportal
Hi dears,
i'm try to create Portal and when I import license the following error appears, so any suggestions?
SuleymanArslan3
Your license file should contains at least one of the following user types which are compatible with the Administrator role. (Assuming your ArcGIS Portal version is10.7 or above.)
- Advanced
- Creator
Insights Analyst
- Standard
https://enterprise.arcgis.com/en/portal/10.8/administer/windows/obtain-portal-license.htm
