Where is the large ESRI colour chart poster?
2273
10-19-2012 10:11 AM
DonovanCameron
Occasional Contributor II
I use to have a large colour chart poster from ESRI.
It shows a couple sections with coloured boxes containing different levels of yellow.
There is text in the bottom middle or two type, Palatino Linotype and another one, maybe arial?
In the bottom left there are examples of the different line colours and widths.
In the bottom right there are examples of shades of grey and others, plus somewhere on the layout there were examples of point sizes.
Does anyone know where I can get this again? Got a different plotter and would like to have that poster printed as a quick visual reference.
I can't find it in the resource centre or ask a cartographer sites. All I found was some small mxds (letter size) with just colour boxes for CMYK, HSV, RGB, etc...
CPoynter
Have you tried opening the two MXDs located at C:\Program Files (x86)\ArcGIS\Desktop10.1\plotters.
I have attached (hope it worked) a PDF of the CMY_Calibrate.mxd which is sized at approximately 914mm x 609mm.
Regards,
Craig
CPoynter
Regards,
Craig
DonovanCameron
Thanks! Those were them.
The one I normally use for calibration is CMY_PlotterCalibrate.mxd
