What Role Type do I need to Change Style of a Feature Layer?
1101
02-06-2023 02:30 PM
platmoskito
Hello, I'm trying to adjust the transparency of the polygons in my Feature Server's feature layer. Logged in the enterprise portal as an admin, I was able to change the style of polygons in the map, but when I logged in to the portal layer later, the changes had disappeared. If this is a permissions issue, what role should I be using to save my style changes?
Scott_Tansley
MVP Regular Contributor
If you have an admin level then you can do ‘everything’. Having a different role won’t help you.
where did you make the change?  Have you tried recreating it since?
Scott Tansley
https://www.linkedin.com/in/scotttansley/
platmoskito
Here's the change I tried to make to the layer. I clicked ok buttons, but the changes are not saved across sessions.
Scott_Tansley
Have you pressed Save Map to save it?  Pressing OK isn't enough.
Scott Tansley
platmoskito
I did not see the Save button. Thanks!
Scott_Tansley
Assuming you're working now?
Scott Tansley
