Webhooks in ArcGIS Portal triggering a flow in Microsoft Power Automate - New URL length
1003
9
09-02-2025 01:18 PM
Jamie_Leitch_CNF
I have a webhook in ArcGIS Enterprise 11.2 that triggers a MS power automate (MSPA) flow to run when a new item is created in Portal. I recently received an email from MSPA stating:
Your flow has a new trigger URL
The flow '<my flow name>' uses the request trigger, and its URL was recently changed. Any tools that  reference the old URL will break starting November 30, 2025.
Flow name: <my flow name>
The email provides this documentation: https://learn.microsoft.com/en-us/troubleshoot/power-platform/power-automate/flow-run-issues/trigger...
When I try to update the URL for the webhook in ArcGIS Portal, I receive this error:
Database error occurred while processing webhook with name or id '<webhook id>' due to 'Unable to update webhook info for webhook with id : '<webhook id>' .'
When I attempt to update the webhook, ArcGIS Portal seems to be sending a "test request" to the URL.  I can confirm this in MSPA and see that the flow runs successfully. But the webhook does not get updated with the new URL.
I have tried creating a new webhook using the new URL from MSPA, and receive this error:
Database error occurred while processing webhook with name or id 'Test' due to 'Unable to add webhook registry named 'Test' for account 'Test'.'
I have noticed that the new MSPA request URL is 290 characters, whereas the old one was 229 characters.  I thought maybe there is a limit in ArcGIS Enterprise for the length of the webhook URL.  I tested this by creating a temporary request URL in webhook.site that is much shorter, and the webhook can be successfully created using this shorter URL (under 255 characters).
Is there a limit on the length of the URL for a webhook in ArcGIS Enterprise?
AndreasHall
I think the bug is BUG-000179555 - When attempting to register an organization webhook in ArcGIS Enterprise using a Power Automate Request connector's "When an HTTP request is received" trigger URL, the operation fails with a database error.
See this post for more details: Solved: Re: Webhook URL update for Power Automate - Esri Community
MikeSchonlau
We have the same question
Jamie_Leitch_CNF
I have engaged with tech support on this and will convey the resolution here when available.
MikeSchonlau
I appreciate it
d-a-v-i-d
I was wondering if you ever heard back from tech support?
I am also having issues with webhook in Enterprise 11.3. Thank you.
StefanUseldinger
Same problem here with ArcGIS Enterprise 11.5
Jamie_Leitch_CNF
I heard back from Support and a defect will be logged for organization webhooks
StefanUseldinger
Thanks for keeping us informed about the bug number so we can follow up 🙂
AndreasHall
Jamie_Leitch_CNF
Yes, that is the bug my support rep logged.
