i successfully install the Portal 10.6.1 on AWS windows Machine with his domain and his SSL , when i try to install the Web adaptor everithins looks good until i acces to the URL http://domail.com/arcgis/home and get this error
any clue?
Did you register the web adaptor with the Portal after installing it?
About the ArcGIS Web Adaptor—Portal for ArcGIS (10.6) | ArcGIS Enterprise
I assume so, as it appears to be attempting to connect to the Portal. Is the web adaptor and the Portal on the same machine? If not, can the web adaptor reach the machine name listed under portaladmin/machines through https://<machine>:7443/arcgis/portaladmin?
