Unable to view Portal Items as an Administrator
1996
02-13-2024 09:22 AM
jfinnegan_hvilletn
Hello all,
Our IT has recently moved up to Enterprise 10.9.1. Previously we used 10.3.1. With the older versions of Enterprise, I would use the Share -- Share as Web Layer -- create Feature Layer/WFS method of pushing things up onto the portal. This would allows me to have REST API endpoints to use for some third party products our city utilizes, and also let me create some web apps as well. Since our update, any time I share items to the portal, it will show up, but I am unable to access the layer in the portal at all. If I then go into the server manager, I can see and access the information there.
I'm currently using ArcGIS Pro 3.0.3 to do these tasks with.
I can't for the life of me figure out what I am doing wrong.
Am I uploading things incorrectly?
Am I using the wrong version of Pro?
Should I be going the old school route, and just uploading items to the server manager?
Is this a known issue?
Any insight or ideas would be a great help.
JP Finnegan
GIS Technician
City of Hendersonville
101 Maple Drive North
Hendersonville, TN 37075
JakeSkinner
Esri Esteemed Contributor
Hi @jfinnegan_hvilletn ,
When you say you are unable to access the portal item, can you elaborate?  Are you getting an error trying to add the layer to a web map?  There should be a URL in the details page of the service:
Are you able to access the Details of the service?
jfinnegan_hvilletn
Hi Jake,
When I go to the contents page, and just click to view any of the layers, it just gets stuck in a loading screen as below.
I'm never able to even view the url/settings screen.
However, if I go into the Server Manager, the WFS is available for viewing
https://gis.abcd.org:6443/arcgis/rest/services/GIS/FeatureServer (this would work).
So, I'm not really sure if its that the Server and the Portal aren't talking, or if  there's some missing permission between the two. Very strange.
JP
Dan_Brumm
Have you checked the Portal index? When that gets out of whack it can cause some weird issues.
Daniel Brumm
GIS Nerd
TimoT
You can try the Reconfigure operation in Portaladmin which was introduced at 10.9.1
This operation rebuilds the index.
Timo
