Unable to Save New Basemap with Different Coordinate System
592
08-14-2025 01:50 PM
RogerDunnGIS
I am using ArcGIS Enterprise 11.5.  Our default basemap is in NAD27.  Therefore, any new maps in Portal have a NAD27 basemap.
I have published a new tiled image cache service in NAD83.  I wish to make a web map using this imagery so that is an available basemap in Portal and ArcGIS Pro.
I open a new map, which has our default NAD27 basemap already loaded.  I add the NAD83 image layer to the map.  I move the new layer to the basemaps section.  I remove the old basemap.  My map has no layers and no tables, and only one layer in the basemaps section.  I try to save the map but get this error:
Failed to save map
The layer, Untitled map, cannot be saved.
I have also tried this: I open the web item page of the imagery layer and click Open in Map Viewer.  Again, I move that layer to the basemaps section, remove the old basemap from that section, and attempt to save.  I get the same error as before.
I suspect that my issue has to do with coordinate systems.  But since I can't tell the map what coordinate system I want to use, and I can't open a map with no basemap at all, I feel stuck.
How can I make my new NAD83 image serve an available basemap in Enterprise without getting an error when trying to save the web map?
EmilyGeo
Hi @RogerDunnGIS
Could you try adding the layer with the Use as Basemap option?
EmilyGeo
Hi @RogerDunnGIS
RogerDunnGIS
Oh, for heaven's sakes.  Yes, that did it.  (palm to forehead)
