Unable to import this shapefile. (Generate Features error: Exception hostname in certificate didn't match: != OR )
2558
11
05-11-2018 09:00 AM
LR
I've set up an AGE Server (Server, Webadaptor x2, Portal, Data Store) on a single self-certified VM and can't add Shapefiles to a map in Portal - it just throws above error. I GUESS this is because in Portal under Servers I added https://localhost:2443/arcgis/datastore and https://localhost:6443/arcgis instead of MACHINENAME.local/yaddayadda and now the SSL certificate does not match.
However, there is no way to remove that entry. Furthermore, when I try to add the Data Store server with the machine name address, portal tells me "ArcGIS Server is already a federated server". How do I fix this, or isn't this the proper way anyway?
Tags (1)
JonathanQuinn
Esri Notable Contributor
The certificate on 6443 is set to the web adaptor machine name? Is the web adaptor on the same machine as the Server? You can use the default self-signed certificate for 6443, that's no problem. If you need to use a certificate signed by your domain certificate authority, then make sure you either set a SAN for the Server machine or create a new one with the CN set to the Server machine.
JohnBrockwell
Hi Jonathan,
That is what I suspected. My ArcGIS Server is on another machine from the Web Adaptor. I created new CSR's and I will import them into ArcGIS Server machine
