Unable to do field calculations using Arcade in Portal
772
11-12-2021 03:51 AM
mddelossantos
I have a hosted feature layer containing a point layer with several related tables.
I'm using Arcade to calculate the total number of related records per point, populating a new empty field. I have 9 empty fields which I am doing calculations on but I'm encountering an unexpected behavior with Arcade.
Sometimes the calculation works and sometimes it doesn't. I'm positive the syntax I'm using is correct since I was able to successfully calculate for 5 out of 9 fields I have. The problem is I have to run Arcade several times as I keep getting this error:
After n number of tries for the 5 fields, I was able to get the values I needed. But still no success with the remaining 4 fields I have. I keep on running Arcade until the calculation is successful.
Is this unexpected behavior a bug or is it something that can be fixed on the server side? Has anyone experienced this in portal? Hope someone can help. Thanks!
jcarlson
I've not seen that message before. Is it possible to attempt the calculation from ArcGIS Pro?
- Josh Carlson
Kendall County GIS
