unable to create the group at this time
5477
15
11-09-2016 10:48 PM
OfraAinemer
I've installed portal for ArcGIS 10.4.1 on a new server, with web adaptor and CA certificate.
While I'm trying to add a group, I get this message "unable to create the group at this time".
Any ideas?
Ofra
PaulDavidson1
Jennie:
Have you tried it with IE?
Same result?
Perhaps check the permissions of the arcgisportal folder?
NadineTrahan1
Jennie, this problem was finally resolved for me as follows. Make sure to install the patch on the machine where Portal is, in our case the server machine. I then got a successful patch install, but still could not create groups until several days later, so I'm guessing after the patch install, you should close and open chrome as well as reboot your own computer?
JennieCatalano1
Hi David.  It worked for me in IE. Thank you so much!
PaulDavidson1
Glad to hear it worked.
That sounds like the 10.4.1 Patch didn't install correctly or you need to reboot the server.
Apply the patch and then reboot the server.
I think the patch directions might say just stop and restart the ArcGIS Server service.  I don't remember.
I prefer to reboot the server for a clean restart on anything like a patch, install, uninstall, repair, etc....
JennieCatalano1
Hello Jayanta. Yes, it worked with IE after installing a patch.
Luiz_AmadeuCoutinho
(Solved) - Installed a new patch ArcGIS-1041-PFA-SEC2017U1-Patch-linux.tar
Hi guys
I installed  Portal for ArcGIS Home Application Upload Patch for linux today, my Portal stopped to work after that.
It was created a extra folder called linux.portal at Portal installation Folder.
I run portaldiag to check the requirements and now I got a Warning Diag_26
DIAG000: Check for installation as root                       [PASSED]
 DIAG001: Check for 64-bit architecture                        [PASSED]
 DIAG002: Check OS version                                     [PASSED]
 DIAG003: Check hostname for invalid characters                [PASSED]
 DIAG005: Check system limits                                  [PASSED]
 DIAG004: Check installed packages                             [PASSED]
 DIAG006: Check OS patches                                     [PASSED]
 DIAG016: Check Portal for ArcGIS ports                        [PASSED]
 DIAG024: Check localhost resolution                           [PASSED]
 DIAG020: Check hostname IP address mismatches                 [PASSED]
 DIAG026: Check processes of Portal for ArcGIS core services   [WARNING]
 DIAG028: Check data directory                                 [PASSED]
 DIAG029: Check file system type                               [PASSED]
There were 0 failure(s) and 1 warning(s) found:
WARNINGS:
*** DIAG026: One or more core services was not started.  Start Portal
for ArcGIS by running the startportal.sh script or restart Portal for
ArcGIS if it is already started.
Any idea to help me? Reinstall Portal will be terrible for me
Thank you.
