SOE capability checkbox disabled
1270
08-24-2023 10:28 AM
YoonsikChu
We set up a new ARCGIS Server 11.1 and registered a .NET SDK SOE.
But when I try to turn on the SOE capability from ArcGIS Server Manager, the checkbox for the SOE is disabled.
The same SOE works fine with another server which is ARCGIS Server 10.9 so it should be related to the server settings. Any ideas?
YoonsikChu
I found why it was disabled. The pool instance type of the service has to be dedicated instance pool. This option doesn't exist in old arcgis server (v10.9 and less).
YoonsikChu
bburnett44
In Java SOEs, you have to explicitly enable support for services that run in shared instance pools. You do this by adding the 'supportsSharedInstances' to the ServerObjectExtProperties attribute.
Looks like the equivalent for dotnet is ServerObjectExtension attribute and it has the same property name
