SLD with PointSymbolizer
3288
09-02-2010 05:08 AM
by Anonymous User
Not applicable
Original User: pablocabrera
Hello,
Im using the WMS service with an external SLD and it works quite well.
The thing is that I've been trying to get a PointSymbolizer with an OnlineResource to work but with no success so far.
When I use a simple "Mark", it works, but when I change it to an OnlineResouce, it doesn't display a thing.
Here are the SLD with the rules:
<?xml version="1.0" encoding="iso-8859-1" standalone="yes" ?>
<sld:StyledLayerDescriptor version="1.0.0"
 xmlns:sld="http://www.opengis.net/sld"
 xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml">
 <sld:NamedLayer>
  <sld:Name>3</sld:Name>
  <sld:UserStyle>
   <sld:Name>pontos</sld:Name>
   <sld:FeatureTypeStyle>
<sld:Rule>
 <sld:Name>My Point</sld:Name>
 <sld:PointSymbolizer>
  <sld:Graphic>
   <sld:ExternalGraphic>
    <sld:OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://somehost/someImage.gif" />
    <sld:Format>image/gif</sld:Format>
   </sld:ExternalGraphic>
   <sld:Size>16</sld:Size>
  </sld:Graphic>
 </sld:PointSymbolizer>
</sld:Rule>
   </sld:FeatureTypeStyle>
  </sld:UserStyle>
 </sld:NamedLayer>
</sld:StyledLayerDescriptor>
The image is accessible, (I'm running ArcGISServer on the same machine as the image) and when I try to open the URL on the browser, it shows up nicely.
Any clues? I don't know what to do... =/
RicoLelina
Did you figure out what's wrong?
by Anonymous User
Not applicable
Original User: bootbr
I'm having exactly the same problem. Has anyone else had the same issue?
MarcVandael
Hi, i know this is an old thread, but I had this problem also. In my case was with a proxy setting. Easiest would be to reference to a file on your own server/host. That fixed it in my case. If this doesn't solve it, you might want to verify your proxy settings.
by Anonymous User
Not applicable
Original User: anakintang
Can you try
<sld:UserStyle>
   <sld:Name>pizza</sld:Name>
   <sld:Title>pizza</sld:Title>
    <sld:Rule>
      <sld:Graphic>
        <sld:OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:type="simple" xlink:href="http://sazabi:8082/openlayers/slds/sanfrancisco/images/pizza.gif" />
        <sld:Format>GIF</sld:Format>
       <sld:Opacity>1</sld:Opacity>
       <sld:Size>12</sld:Size>
       <sld:Rotation>0</sld:Rotation>
      </sld:Graphic>
    </sld:Rule>
  </sld:UserStyle>
Be care on the <sld:Format>GIF</sld:Format>, there seems to be a bug if you put image/gif.
Thanks.
