shut down and start up AWS portal
4857
8
11-08-2020 06:00 PM
DeanHowell1
What is the correct sequence to shut-down and then start-up ArcGIS, Portal and the Datastore on AWS?
Is there a script that will handle it so we can close down at 7pm and start-up at 7am, for example?
2 Solutions
DavidHoy
but when the Enterprise configuration is HA with multiple machines, you need to be more careful.
If a Primary Portal or Data Store machine is taken down, the Standby will try to take on that role. If the timing goes bad, you may get "split-brain" problems when the machines are brought back up. i.e. two servers both thinking they are "Primary".
You need to check manually which machine is Primary and which Standby, then ensure the shutdown order is:
  • Portal Standby
  • Portal Primary
  • Hosting Server(s)
  • Any other Federated Server(s)
  • Data Store Standby
  • Data Store Primary
then reverse for Startup
  • Hosting Server(s)
  • Portal Primary
  • Portal Standby
 If this is to be scripted - you could call the REST endpoints to find the current status of the machines in each tier.
There is also a need to wait for the individual processes (Windows Services) and associated GIS services to stop / start completely between each step
DavidHoy
Hi @DeanHowell1
In your particular case, where you have each tier separated and with multiple machines, each running one of the pieces - then yes - just shutting down the machine is fine.
On startup, the windows services will restart themselves as well.
The Lambda functions for shutdown and startup do need to be updated to include the specific order and some wait times. There are known problems when two machines in a tier (e.g. Portal) start at the same time.
Travis_Esri
Good question! There is no recommended or necessary order to start/stop up ArcGIS Enterprise. The only caveat being that in order to log in to a federated server, Portal must be running. If you are starting/stopping them all at the same time then this really wont affect your situation. I am sure there are scripts that will accomplish this goal but they will not be Esri-specific. I am sure you could create a scheduled task to stop/start the service. Outside of that I am sure that it would be possible to start/stop the whole server(s) via AWS and its console/API. Any documentation you may find is going to be from Amazon/Microsoft as starting/stopping programs is not Esri-specific.
Hope this helps!
Travis
DeanHowell1
Thanks @Travis_Esri , very much appreciate you taking the time reply.
DavidHoy
  • Portal Standby
  • Portal Primary
  • Hosting Server(s)
  • Hosting Server(s)
  • Portal Primary
  • Portal Standby
DeanHowell1
Thanks @DavidHoy and yes this is exactly what needs to be done so I do appreciate the extra information. Now to figure out the coding part 🙂
DeanHowell1
Thanks again @DavidHoy
Just another question, do you need to worry about shutting down the services on the individual machines first or is it fine just to shot down the ASW machines in the order you suggested in your response above?
DavidHoy
Hi @DeanHowell1
DiegoLlamasOlivares
Hello Travis,
I have implemented an Enterprise in  a single machine in AWS.  I am doing some test with this 10.7.1 Enterprise, and after this i shutdown the machine in order Amazon do not charge me for a machine i do not use.
But for some reason, everytime i turn of the VM, or I stop instance from AWS console, ArcGIS Enterprise get corrupted and I need to recreate my insulation again. I have tried even stom Portal, server and datastore services before turn off the VM or stop instance, but the problem continues.
Portal1.PNG Error I get from Portal
Error I get from server when I restart instance
and Data Store seems like never was configured with Server.
Any idea why it happend?
Diego Llamas
DeanHowell1
Does anyone know how to code this using AWS Lambda?
