set the default date format for my portal
1900
7
04-22-2020 02:46 PM
CarolynMilland1
Whenever I publish or overwrite a service, the date format defaults back to US MM/DD/YYYY, so, I have to change it every time I update a service. My language and date format is set to the correct region in the My Organisation settings, but it makes no difference. Am I missing something? Can I set the date/time format so that it is set to my region? ie: DD/MM/YYYY
AngelaDeegan
Yes, I've noticed whenever I publish or overwrite a service, all the date attributes in popups revert to a format that includes a time component (which we don't want). And we have to go through each popup and individually uncheck the "Show Time" box in the "Configure Attributes" window in the map. It would really help if there was a global setting for this.
TimMinter
I agree.  Thumb this up if you're willing - https://community.esri.com/ideas/17706
AngelaDeegan
Thanks. That issue is related to this, but a bit different. We actually have a a gnarly situation within our GIS our date fields related to time zones - with different scenarios for the following in both Pro and Portal:
  • editor tracking date fields
  • "regular" date fields where the values are from data that we imported from our old (Smallworld) GIS
  • "regular" date fields which we're now populating in Pro
Once we've got a better handle on how to resolve our issues I'll be in a better position to know whether the idea you posted would be likely to work in a case like ours.
by Anonymous User
Not applicable
I think as a community we need to have something like this idea
ESRI default date JSON display format across entire suite of platforms
JackFanZhang
Having the same issue as of Dec 2021. just wondering if ESRI is ever going to notice that the default datetime format MM/DD/YYYY is causing some headache to users that outside USA.
İSMAİLGÖKDUMAN
I HAVE THE SAME PROBLEM, IN THE PRINTING SERVICE THE DATE FORMAT RECEIVED FROM THE PORTAL COMES AS MM/DD/YYYY NO SOLUTION?
İSMAİLGÖKDUMAN
Copying the date format from control panel-region settings for all users and devices solved my problem.
