Script to Create New Label by Deleting after a comma & Splitting into 2 lines
5066
17
05-16-2014 11:54 AM
TiaMorita
I am using the ESRI CBSA feature class, and the names are super long, for example:
Anniston-Oxford-Jacksonville, AL Metropolitan Statistical Area
I want a VBscript or python script to use as a label expression to delete all words after the comma, and then stack the label into 2 lines, for example:
Anniston-Oxford-
Jackson
Any suggestions? Thanks!
TiaMorita
Whoops left off a + sign
def FindLabel ( [Name] ):
  Split = [Name].split(",")
  Split = Split[0] #drops everything after comma
  Split = Split.split("-") #splits by the hyphen
  if len(Split) == 2:
    expression = Split[0] + "- \n" + Split[1]
  elif len(Split) == 3:
    expression = Split[0] +"-" + Split[1] + "- \n" + Split[2]
  return expression
GIve that a shot.
Hi there - the results comes out empty 😞
TiaMorita
Here is some sample data to help out. Both of you are close, so hopefully this will help!
IanMurray
Honored Contributor
from your reply, you didn't use my most recent script, or at least you didn't post it back.
  if len(Split) == 2:
    return expression
    expression = Split[0] + "-" + Split[1] + "- \n" + Split[2]
    return expression
Edit: Also, the attribute table for that file was empty.
Edit Again: NVM, I didn't unzip properly
IanMurray
Honored Contributor
  if len(Split) == 2:
    return expression
    return expression
  else:
    return Split[0]
Likewise mine labelled all the samples.  It will only work if there are 3 or less cities names in the name field.
I like yours Sol, except it splits single names in half, I think those ones would be fine on one line, but I guess its not my call.
[ATTACH=CONFIG]33885[/ATTACH]
TiaMorita
It worked for me with the sample data you sent.
Function FindLabel ([NAME])
pos = instr([NAME],"," )
lab =  Left([NAME], pos - 1)
leng = len(lab)
half = Int(leng/2)
first = left(lab,half)
digits = leng-half
nex = right(lab,digits)
 FindLabel = first & vbnewline & nex
End Function
Thanks, Sol
No - this was the result I got (see attached).
TiaMorita
 def FindLabel ( [Name] ):   Split = [Name].split(",")   Split = Split[0] #drops everything after comma   Split = Split.split("-") #splits by the hyphen   if len(Split) == 2:     expression = Split[0] + "- \n" + Split[1]      return expression   elif len(Split) == 3:     expression = Split[0] + "-" + Split[1] + "- \n" + Split[2]     return expression   else:     return Split[0]
Actually - I think this it! Looks like it works! 🙂
IanMurray
Honored Contributor
Yeah, I agree splitting the text in half like that is not really nice, but the OP said that it didn't matter so I didn't make it more complicated.  Plus I'm racing against you to figure it out. lol 🙂  Plus I have to leave work now...
Haha, pretty much the same here.  From the two examples that were given I figured she wanted them to be split by the city names so thats what I went for.  Nothing wrong with yours, just a stylistic difference 😉
Edit:  Dang, she marked her quote of my response as answer, no answer provided for me 😞
IanMurray
Honored Contributor
Yours worked, it just wasn't quite stylistically what they wanted I suppose.
Go home and have a good night!
