Saving edits on a Portal Item Error
2838
11-03-2016 01:32 PM
ZachSturm
Whenever I edit anything in Portal, whether it be an Feature Service, Map Service or Item....I get:
'Error
Unexpected token <'
Any thoughts on what could causing this?  I am using a federated portal with arc server.  Everything besides editing the feature properties (Name/Extents/Summary/Description) are working.
RyanUthoff
MVP Regular Contributor
Have you tried using Internet Explorer? I believe this is a known bug. I have been having this problem as well. See the blog link below.
Announcement: Errors Encountered in ArcGIS for Server and Portal for ArcGIS Web Apps after Certain B...
ZachSturm
Good call, thanks.  IE worked fine, was a browser issue.
DerekLaw
Esri Esteemed Contributor
Hi Zach,
Please apply this patch to address the issue, Portal for ArcGIS Home Application Upload Patch
Hope this helps,
ZachSturm
Thanks for the link, patches worked great.
