Refresh ArcGIS Notebook Token
1241
02-16-2024 01:23 PM
CodyPatterson
MVP Regular Contributor
Hey all,
Enterprise 11.2, Linux Containers Notebooks
Recently, I've been getting this when starting a new Notebook, it will happen for all users:
If I press Jupyter Notebook, I get this:
Any way to change the token to the correct one? Just looking to change the token itself, maybe there's a config file somewhere? I've found some tokens before but haven't been able to find if they're the right ones!
Thanks in advance!
Cody
GeoNomad
Following..We're having the same issue with the Notebook Server (Linux) on 11.2. Our issue started while migrating to a new server. @CodyPatterson I'll relay any updates we get on our end. Please, please let me know if you found a resolution as well! Thank you.
CodyPatterson
Hey @GeoNomad
I was able to get most of the Notebook issues resolved by changing a WebContextURL on the Notebook server itself. If you have a reverse proxy or are redirecting the traffic in any way, it seems to be the solution if we change the URL. Example:
Portal is https://arcgis.reverse-proxy.com/portal
Notebook was https://arcgis.notebook.local/notebook
Changed to https://arcgis.reverse-proxy/notebook
That had seemingly fixed the issue, now we are at a point where it immediately fails connecting to the kernel, so we're reaching out to professional services to get this checked out, I also have a ticket open, so I can let you know what happens!
Cody
