Publish from ArcPro with map extent
859
11-04-2022 10:43 AM
ErichSchreier
Hello!
I am publishing a Map Image from ArcPro to portal. In the pro project I have an extent set on the map but when it is published, the extent is removed.
Is there a way to publish and maintain the same extent that is designated in pro?
Thanks
by Anonymous User
Not applicable
I would manage the extent setting on the Portal item itself, under settings, map extent, and select set extent by features in the layer.
