Problem loading services in Portal for ArcGIS
3404
6
11-06-2015 04:29 AM
OmolaraKareem
Hello,
Can anyone tell me why I am recently seeing the screenshot below. I never used have the problem in the past.
Lara
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Omolara,
It looks like the service is secure.
Is ArcGIS Server federated with Portal?  If not, are you using Built-in security for ArcGIS Server?
OmolaraKareem
Thanks for your prompt response Jake.
No to all your questions. I am truly baffled, because I didn't have this issue until very recently and I don't know how to solve it.
Any suggestions you can provide will be highly appreciated.
Lara
Sent from Samsung Mobile
JakeSkinner
If you try to access the service just by pasting the URL into a web browser, are you prompted for credentials?
OmolaraKareem
Jake,
I think I have found a solution, I however need to understand what’s going on better.
My solution: I checked the URL of my older layers on Portal for ArcGIS that are fine and noticed that they all were from the third URL. However, my newer layers that have been giving me problems were from the first and second URL. So, what I did was copy the affected layer urls from the third path and all is well again.
What I hope you could explain to me, is why I have these varying service URLs.
http://lamata-gissvr.lamata-ng.com/arcgisserver/rest/services/
https://lamata-gissvr.lamata-ng.com/arcgisserver/rest/services/
http://lamata-gissvr:6080/arcgis/rest/services
Lara
JakeSkinner
The 3rd URL is bypassing the web adaptor.  You may want to check how you have the web adaptor's authentication set up.  You can do this by going to IIS Manager (start > run > inetmgr) > Sites > Default Web Site > arcgisserver > Authentication.  You will see something similar to below.
OmolaraKareem
Thanks Jake. That is exactly what I saw. What do you think I should do about this by-passing issue?
