Printing at higher resolution w/ ArcGIS online
1836
06-29-2018 12:23 PM
JasonLoxton
Is there a way of printing at higher resolution in ArcGIS online? I have been trying for days and going insane. I need to export maps as images to put into a guidebook I am working on, but cannot find any way to do it that does not look terrible. The default print resolution is too low and using the desk top 'snip' isn't really good enough either (although  it is better). I would have assumed that this was basic functionality in the application and am baffled that there doesn't seem to be an obvious way to do it. Help!
Jason
JonathanQuinn
Esri Notable Contributor
Are you in the webmap viewer or in a web application, like the Web Application Builder? Do you have your own ArcGIS Server? If so, you can create your own print service to use in your organization:
Printing in web applications—Documentation (10.5) | ArcGIS Enterprise
High quality printing can be achieved as well:
Tutorial: Advanced web map printing/exporting using arcpy.mapping—Documentation | ArcGIS Enterprise
