portal webadapter cant access /arcgis/portaladmin
1762
08-30-2018 01:49 PM
WilliamWinslow
When accessing through webadapter I can no longer access /arcgis/portaladmin
works when not accessing through webadapter
I believe this is also causing /arcgis/home/signin.html to not work while using webadater
portal runtime tomcat localhost log error:
30-Aug-2018 16:42:01.660 SEVERE [https-jsse-nio-7443-exec-6] org.apache.catalina.core.StandardWrapperValve.invoke Servlet.service() for servlet [default] in context with path [/arcgis/portaladmin] threw exception
 java.lang.NullPointerException
        at com.esri.arcgis.portal.admin.rest.filters.AdminFilter$PortalRequestWrapper.a(AdminFilter.java:297)
        at com.esri.arcgis.portal.admin.rest.filters.AdminFilter$PortalRequestWrapper.<init>(AdminFilter.java:167)
        at com.esri.arcgis.portal.admin.rest.filters.AdminFilter.doFilter(AdminFilter.java:63)
        at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
        at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
        at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:198)
        at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
        at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
        at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
        at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:80)
        at com.esri.arcgis.portal.util.TomcatValve.invoke(TomcatValve.java:43)
        at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
        at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
        at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:799)
        at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
        at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:861)
        at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1455)
        at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
        at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
        at java.lang.Thread.run(Thread.java:748)
WilliamWinslow
problem with /arcgis/home/signin.html redirect problem was solved by configuring WebContextURL
WilliamWinslow
