Portal randomizes polygons in pop up
365
09-05-2019 02:20 PM
JoeBorgione
I have created monthly delivery data for a year and display the data in zipcode polygons. Subsequently, for a county wide map of zipcodes, there are 12 polygons for each zipcode.  The data is updated in monthly runs so the 'first' polygon is January, and the last is December.  When viewing the popup for a given zipcode in ArcGIS Pro, the months are returned in order:
However, after publishing the data to Portal, when I view the pop up, the months data seem to be in a random order. (Keep and eye on the 'Month' field)
The portal map is being used in a Portal operations dashboard; ideally, with a zipcode poly clicked for a pop up, it would be nice if the user can see the months in order as I do in Pro.
Any ideas as to what is going on and is there a fix for this?
