Portal Invalid redirect_uri error 400
7938
06-06-2017 08:14 AM
StefanieCannon1
I am trying to get my portal working and I am running into issues.
I am accessing my portal via a domain name pointing to my arcserver.
When I try to log-in or go "groups" it keeps trying to route to my servers path vs the domain path I entered.
How can I fix this?
I looked at fixes for older versions of portal, but those options are not available on 10.5.
Any guidance on this would be appreciated because I have been looking at this for 2 weeks. Thank you.
JakeSkinner
Esri Esteemed Contributor
Hi Stefanie,
Log onto your Portal Administrator Directory (https://server.domain.com:7443/arcgis/portaladmin) and navigate to System > Web Adaptors > click on the server name.  At the top of the web browser, add /edit to the URL.  Check to make sure the Web Adaptor URL in the following page is using the correct DNS name.
JakeSkinner
Hi Stefanie,
StefanieCannon1
Thanks Jake! That worked well. I have tried to do that in the past, but apparently it won't let me do it through the web adaptor url.
